Tig Welding Thick Carbon Steel Settings from 11ga up to one inch thick
11 ga (.120") carbon steel TIG settings
tig welder settings for 11ga 2f tee carbon steel
tig welder pulse settings for 11ga 2f tee carbon steel
tig welder settings for 11ga carbon steel 1F outside corner joint
tig welder settings for 11ga carbon steel outside corner pulse settings
settings for 2f 11ga lap joint carbon steel
tig welder settings for 3f 11ga carbon steel lap joint
settings for 4f overhead TIG 11 ga
TIG Settings for .125" and thicker carbon steel
tig welding carbon steel 1/4" thick at 170 amps
1/4" carbon steel tig welder settings
settings for tig welding  thick high strength steel
settings for TIG welding Carbon Steel pipe
Tig welding thick carbon steel tips
Tungsten electrodes have an upper range amperage limit and for some reason, tungsten amperage range charts seem to be very generous on the upper limits.
For example, some charts rate a 1/16" at up to 150 amps.
personally, I think a limit of 100 amps is more accurate for a 1/16" diameter tungsten.
a 3/32" tungsten works fine up to around 200 amps.
For Tig welding thick carbon steel at over 200 amps,  I recommend going to 1/8" tungsten in either 2% lanthanated, 2% thoriated, or 2% ceriated.
