TIG WELDING STAINLESS STEEL .050" HOLE FILL
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS =  .050"
WELD TYPE =  HOLE FILL
JOINT TYPE = HOLE FILL
POSITION = FLAT
AMPERAGE = 40-50 AMPS.
FILLER WIRE = 1/16” ER308L
GAS FLOW = 25 CFH argon
CUP SIZE =  12
ADDITIONAL SETTINGS =    PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: ALUMINUM OR COPPER BACKING WORKS GREAT.
IN SOME CASES ARGON BACKING GAS IS NEEDED.
KEEP A FAIRLY TIGHT ARC
tig welding hole in sheet metal
