TIG WELDING STAINLESS STEEL .120" WALL COPED TUBE
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = 304L STAINLESS STEEL TUBING 1-1/2"
THICKNESS =  .120"
WELD TYPE =  COPED TUBE JOINT
JOINT TYPE = COPED TUBE JOINT
POSITION = FLAT
AMPERAGE = 100-120  AMPS.
FILLER WIRE = .045” ER308L
GAS FLOW = 20-25 CFH argon
CUP SIZE =  10
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
A few tips for TIG welding Stainless steel...
  • get that puddle established and moving within 2 seconds to prevent heat buildup.
  • use a gas lens with #8 or larger cup (jazzy 10 ceramic is great)
  • sometimes using one size smaller filler rod helps with stainless steels
