TIG WELDING STAINLESS STEEL16GA LAP SETTINGS
scroll down for weld settings
Did you know?…
  • And that it is included as part of the membership?
  • And that you can check it out as part of your free trial?
  • And that if you use promo code QS25 you will get 25% off your first 3 months?
  • Easy to sign up
  • Even easier to cancel without any hoops to jump thru.
THICKNESS =  .063"
WELD TYPE =  FILLET
JOINT TYPE = LAP
POSITION = 2F
AMPERAGE = MACHINE SET TO 65 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = .045” ER308L
GAS FLOW = 20-25 CFH argon
CUP SIZE =  10
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
tig welding stainless
