METAL TYPE = 304 STAINLESS STEEL
THICKNESS = 2 INCH
WELD TYPE = BUILD UP PASSES
JOINT TYPE = BUILD UP PASSES
POSITION = FLAT
AMPERAGE = 120-150 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” ER308L
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
LET COOL TO BELOW 250F BETWEEN PASSES TO MAINTAIN STAINLESS PROPERTIES
Whether you are a student, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
