TIG Welding Stainless Keyway
METAL TYPE = 303 STAINLESS STEEL FREE MACHINING
(303 IS NOT RECOMMENDED FOR WELDING FOR CRITICAL WELDS)
THICKNESS = 2 INCH
WELD TYPE =  BURN DOWN AND BUILD UP PASSES
JOINT TYPE = BUILD UP PASSES
POSITION = FLAT
AMPERAGE = 150 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” ER308L
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
