TIG WELDING STAINLESS .063" WALL SANITARY TUBE WITH SCRATCH START RIG
scroll down for details and settings used
TIG welding sanitary stainless tubing is all about the purge and the inside of the tube. Of course you want the outside of the weld to look good too but the quality of the purge and smoothness of the root is the main desired outcome.
THICKNESS =  .063"
WELD TYPE = GROOVE WELD NO BEVEL
JOINT TYPE = BUTT
POSITION = 6G
AMPERAGE = 45 AMPS
FILLER WIRE = NONE autogeneous
GAS FLOW = 20 CFH argon
CUP SIZE =  7
5 CFH ARGON PURGE
PRE FLOW = TORCH VALVE
POST FLOW = TORCH VALVE
Did you know?..
