TIG WELDING PARTIAL PEN GROOVE STAINLESS TO HIGH STRENGTH CARBON STEEL WITH 309 FILLER
scroll down for settings
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
METAL TYPE = HIGH STRENGTH STEEL TO 304L STAINLESS STEEL
THICKNESS = 1/2’ TO 1/4"
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 1G
AMPERAGE = MACHINE SET TO 160 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” ER309L
GAS FLOW = 20-25 CFH argon
CUP SIZE = 12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
For TIG welding 300 series stainless to high strength steels, either a 309L or 312L filler rod can be used.
Both work fine but 312 is very crack resistant
We have both 309 and 312 TIG rod at weldmonger.com
Did you know?...
***Its Easy to sign up
No Ads, No BS style
