TIG WELDING 12L14 TO HSS settings
12L14 steel is not really recommend for welding but if you do any work for machine shops you might need to weld some light duty applications like pressed in bosses
METAL TYPE = CARBON STEEL 12L14 free machining steel
THICKNESS = 1" plate to machined fitting
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F
AMPERAGE = 140 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
12L14 free machining carbon steel is not recommended for welding but for certain low stress applications it can be welded satisfactorily.
12L14 has a tendency to undercut easily even when tig welding.
to avoid undercut, let the puddle flow out to the toes of the weld and try not to play the arc directly on toes of weld
Did you know?..
