TIG WELDING PULSE SETTINGS CARBON STEEL TUBE ON TURNTABLE
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
038 thick carbon steel washer to .040" pulse settings
METAL TYPE = CARBON STEEL TUBE TO WASHER
THICKNESS = .038" WASHER TO .040" WALL TUBE
WELD TYPE = FILLET
JOINT TYPE = CORNER JOINT
POSITION = TURNTABLE
AMPERAGE = peak amps set at 100 controlled with foot pedal
FILLER WIRE = NONE
GAS FLOW = 25 CFH argon
CUP SIZE = 12
PRE FLOW = .5 SEC
POST FLOW = 11 SEC
ADDITIONAL SETTINGS = PULSE SETTINGS 2 PPS, 20% PULSE TIME, 20% BACKGROUND AMPS
TIPS: KEEP A TIGHT ARC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
