TIG WELDING CARBON STEEL TUBING .055" FILLET WELD
Did you know?..
METAL TYPE = CARBON STEEL  SQUARE TUBE
THICKNESS =  .055” WALL THICKNESS
WELD TYPE =  FILLET
JOINT TYPE = COPED TUBE FILLET ROUND TO RECTANGLE
POSITION = FLAT
AMPERAGE = MACHINE SET TO 59 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = .045” ER70S6
GAS FLOW = 20-25 CFH argon
CUP SIZE =  12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
