TIG WELDING CARBON STEEL THINWALL .063" TUBE LAYWIRE 3/32" ROD
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL SQUARE TUBE .063” WALL
THICKNESS = .063"
WELD TYPE = FILLET weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = 70 amps
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10
ADDITIONAL SETTINGS = PRE FLOW = .5 SECPOST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
