Tig Welding Carbon Steel 2 inch schedule 40 socket weld turntable
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld MULTIPASS SOCKET WELD
JOINT TYPE = SOCKET WELD
POSITION = ROTATED USING A POSITIONER - HORIZONTAL
AMPERAGE = 170amps
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20-25 CFH argon
CUP SIZE = 10
PRE FLOW = .5 SEC
POST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
var l = window.location.href,
d = document;
