Tig Welding Carbon Steel socket weld 1/4" wall Fill and cap settings
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = WALL THICKNESS 1/4”
WELD TYPE = Fillet weld
SOCKET WELD SECOND PASS AND CAP
JOINT TYPE = SOCKET WELD
POSITION = IN TRIPOD VISE 5F
AMPERAGE = 135-140 amps ( 140 FOR SECOND PASS OVER ROOT…135 FOR CAP)
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS = LIFT ARC PRE FLOW = .5 SECPOST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
tig welding socket weld
