weldmonger-banner-dual-flow-free-gas-tester-deadline
TIG WELDING CARBON STEEL 1/4" WALL TUBE TO 3/8" FITTING PULSE SETTINGS
Scroll down for exact pulse settings used
To get the best results out of a turntable weld, you need to be steady.
sometimes I set up a prop stand but for these welds a TIG Finger® was a quick way to prop right next to  the red hot weld
WELD PROCESS = TIG, GTAW, GAS TUNGSTEN ARC WELDI
METAL TYPE = AISI 1020 CARBON STEEL
THICKNESS = 1/4” WALL THICKNESS TUBE TO END FITTING
WELD TYPE = GROOVE WELD- PARTIAL PENETRATION
JOINT TYPE = BUTT PARTIAL PEN WITH CHAMFER
POSITION = ROLLED ON TURNTABLE
AMPERAGE = MACHINE SET TO 200 AMPS CONTROLLED WITH PEDAL
FILLER WIRE = 3/32” E70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10
ADDITIONAL SETTINGS =  PULSE SETTINGS 2 PPS, 50% PULSE TIME, 35% BACKGROUND CURRENT, 1 SECOND UPSLOPE, 5 SECONDS DOWNSLOPE
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
