TIG WELDING CARBON STEEL ON TURNTABLE 1/4" WALL TUBE TO 3/8" FITTING FILLET WELD
Quick video showing walking the cup using a turntable.
This was a short production run of 50 carbon steel parts and the turntable really sped things up
METAL TYPE = CARBON STEEL
THICKNESS = 1/4” WALL THICKNESS TUBE TO END FITTING
WELD TYPE = FILLET
JOINT TYPE = FITTING INSERTED INSIDE TUBE
POSITION = ROLLED ON TURNTABLE
AMPERAGE = 180-190 AMPS
FILLER WIRE = 3/32” E70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC AND MAKE SURE THAT ELECTRODE EXTENSION IS CORRECT TO ALLOW FOR WALKING THE CUP OR FREEHAND TECHNIQUE
