TIG WELDING CARBON STEEL1/4 INCH LAP 2F ER70S2 AND ER70S6
METAL TYPE = CARBON STEEL
THICKNESS =  1/4”
WELD TYPE = Fillet weld
 JOINT TYPE = LAP JOINT
POSITION = 2F
AMPERAGE = 170 amps
FILLER WIRE = 1/16” ER70S2, ER70S6
GAS FLOW = 20CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
FOLLOW THE WELDING PROCEDURE FOR TYPE OF FILLER ROD
Did you know?...
***Its Easy to sign up
No Ads, No BS style
