Tig Welding Carbon Steel 1/4" wall socket root pass pulse settings
wtt-banner-free-3pk-tungsten
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 1/4” WALL THICKNESS PIPE TO FITTING
WELD TYPE = FILLET
JOINT TYPE = SOCKET WELD
POSITION = ROLLED ON TURNTABLE
AMPERAGE = MACHINE SET TO 210 AMPS CONTROLLED WITH PEDAL. OUTPUT AMPS 160-180
FILLER WIRE = 1/8” E70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10
ADDITIONAL SETTINGS =  PULSE SETTINGS 2 PPS, 60% PULSE TIME, 60% BACKGROUND CURRENT,
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
tig welding carbon steel with pulse
