TIG Welding 4130 chromoly, Stainless Steel, Aluminum, and Titanium
Yep, this video has all that and more
The first video gives great tips for tig welding carbon steel, 4130 chromoly, stainless, aluminum, and even titanium.
Sanitary Stainless Tube welding tips
sanitary-thumb
This second video is about sanitary stainless steel welding.
The things that really make a difference when tig welding different metal types is more than one single thing....but its also not a 100 things.
It is mostly metal prep, arc length, torch angle, argon shielding, and technique.
But let's start with metal preparation.
You need to be welding clean metal that is free from oxide layers, mill scale, paint, oil, coatings, or paint,.....clean bright metal.
Next you need good argon shielding.
and for stainless sanitary welding, you need good argon shielding on the inside as well as outside of the tubing.
The cups that come with your tig torch or welder are just ok for getting started.
But for getting the best results on a variety of metals, they fall short.
tig-pro-kit-17-open
To get the best results, you need the right TIG cup for the application.
That does not mean every situation requires a different TIG cup.
There is a big difference in just getting by with something that works and having the best cup for the job.
As welders, we get thrown into the deep end of the pond sometimes and it helps to have an arsenal of TIG cups and hardware to choose from to get the best possible result.
The Weldmonger® TIG pro Kit is like a  Swiss army knife of TIG cup Kits with a cup for nearly every situation you might encounter.
The TIG pro kit has the most popular Furick cups along with large diameter gas lens cups and hardware.
One of the best things about a TIG kit like this is that you can be sure it all fits your TIG torch.
9 20 tig torch collet bodies
TIG cups are sized by 1/16" increments so a #4 is 4/16" or 1/4" inside diameter.
A #4 tig cup is useful for welding at extremely low amperage and low argon flow rates...for saving argon gas when the welding supply is closed and  also for flash tack welding sheet metal.
A #5 is a favorite of a lot of tig welders for tig welding aluminum up to around .125" (3.2mm) thick
A #6 gas lens is a great all around cup for aluminum and so is a #7 or #8 when using a 1/8" tungsten.
A gas lens #6 cup will let you extend your tungsten much further than a standard collet body #6 cup. And sometimes you need to extend the tungsten to reach a weld.
If you weld stainless, 4130 chromoly, tool and die repair, or nickel alloys like inconel, a Jazzy 10 or Furick ceramic fupa 12 are both great choices.
We have made it easy for you with our high quality TIG cup Kits.
If you are still using the standard collet body cups that came with your TIG torch, you are probably not getting the best results possible.
The very first kit I would recommend to anyone using an air cooled 17 style torch is our Weldmonger® stubby gas lens kit
