TIG WELDING CARBON STEEL 3/8" 2G PLATE HOT PASS OVER ROOT 120AMPS SCRATCH START
Scroll down for Details and Settings used
METAL TYPE = carbon steel
THICKNESS = 3/8"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 2G PLATE OPEN ROOT HOT PASS
AMPERAGE = MACHINE AMPS SET TO 120 USING SCRATCH START TORCH WITH VALVE
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8PRE FLOW = TORCH VALVE
POST FLOW = TORCH VALVE
Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
Did you know?..
