TIG WELDING CARBON STEEL 1/4 INCH 2F FILLET WELD 170 AMPS TEE
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 170amps
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
