TIG WELDING CARBON STEEL 18 ga 2F OUTSIDE CORNER JOINT WITHout CHILL BARS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 18 GA
WELD TYPE = FILLET
JOINT TYPE = CORNER JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 55 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.
tig welding 18ga carbon steel
