TIG WELDING CARBON STEEL18 ga 2F OUTSIDE CORNER JOINT WITH CHILL BARS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 18 GA
WELD TYPE = FILLET CORNER
JOINT TYPE = CORNER JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 60 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10P
RE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup
tig welding 18ga corner
