TIG WELD CARBON STEEL 11GA 3F LAP JOINT
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 11ga
WELD TYPE = fillet weld
JOINT TYPE = LAP JOINT
POSITION = 3f VERTICAL
AMPERAGE = 105 amps with foot pedal (actual amperage 95-105)
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup
tig welding carbon steel lap joint
