Tig Welding 11ga Carbon Steel edge bead pulse settings
wtt-banner-free-3pk-tungsten
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = carbon steel
THICKNESS = 11ga
WELD TYPE = SURFACE EDGE BEAD
JOINT TYPE = EDGE BUILDUP
POSITION = FLAT
AMPERAGE = MACHINE AMPS SET TO 130 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
ADDITIONAL SETTINGS =  PULSE SETTINGS 50PPS, 33% BACKGROUND, 33% ON TIME
TIPS: KEEP A TIGHT ARC
tig welding edge bead
