TIG WELDING CARBON STEEL 11GA OVERHEAD 4F
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 11ga
WELD TYPE = fillet weld
JOINT TYPE = TEE JOINT
POSITION = 4F OVERHEAD
AMPERAGE = 120 amps
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
tig welding overhead
