TIG CARBON STEEL .055" WALL COPED TUBE
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = .055"
WELD TYPE = FILLET
JOINT TYPE = COPED TUBE JOINT
POSITION = FLAT
AMPERAGE = 55 amps with foot pedal
FILLER WIRE = .045” ER70S6
GAS FLOW = 20 -25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
