TIG WELDING CARBON STEEL .038" THICKNESS 1G TEST PLATE
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 18 GA
WELD TYPE = GROOVE
JOINT TYPE = BUTT JOINT
POSITION = 1G FLAT
AMPERAGE = 45 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 -25 CFH argon
CUP SIZE =  10
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
 TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup
tig welding carbon steel
