Tig Welding Carbon to Stainless Socket weld 1/4" wall 309 filler cap
Weldmonger large diameter gas lens kit with CK parts is great for walking the cup
Our new LArge Diameter Gas lens kit now comes with 5/32" setup for those high amperage jobs
large diameter gas lens close up
scroll down for settings
More Walking the cup Videos here
TIG welding videos
Whether you are welding a butt joint or a socket weld, walking the cup is a good technique to learn.
Walking the cup helps with uniformity and even speed.
Of course, you also need to be able to freehand when things are in your way.
Did you know?..
METAL TYPE = CARBON STEEL TO STAINLESS
THICKNESS = WALL THICKNESS 1/4”  ( 2 INCH SCHED 40)
WELD TYPE = Fillet weld  SOCKET WELD 3RD PASS COVER PASS
JOINT TYPE = SOCKET WELD
POSITION = TURNTABLE
AMPERAGE = 140 amps
FILLER WIRE = 1/8” ER309
GAS FLOW = 20CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =  PRE FLOW = .5 SECPOST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
walking the cup stainless
