holiday-deals-banner
tig welding boiler tubes
by Austin
(Cave City, AR, U.S.)
I'm in welding school right now and when i get out i have a job lined out for welding boiler tubes.
First off have you ever welded on a boiler tube and was it hard to get your tig torch on the side of the tube since the tubes are so close together.
Do you walk a cup around it or free hand? Last but not least if you had a half inch gap between your tubes how would you start to even put your root pass in and then how would you finish it out?
Yes i have welded boiler tubes.
there are tricks for when they are so close together that you will learn from the other hands.
sometimes you use a steel wedge to get a little more space.
I have also buddy welded with another welder on the other side where we handed off the arc without ever stopping. sounds wierd, by you will learn what i am talking about..
I mostly freehanded on boiler tubes.
in a pipe stand, walking the cup is not very practical in the field ...for me anyway.
good luck,
