TIG WELDING 4130 1" THICK PREHEAT LAYWIRE
Watch full length video here
9 20 tig torch collet bodies
METAL TYPE = 4130 chromoly
THICKNESS = 1-1/4"
WELD TYPE = FILLET
JOINT TYPE = TEE LAPJOINT
POSITION = 2F HORIZONTAL
AMPERAGE = 165 amps with foot pedal
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
ADDITIONAL SETTINGS = 500F PREHEAT PRIOR TO WELDING
TIPS: KEEP A TIGHT ARC
Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
4130 chromoly can be welded without a preheat using er70s-2 filler wire provided the thickness is .120" or less.
thicker 4130 needs a preheat to slow the cooling rate to prevent brittle zones.
