TIG WELDING 4130 CHROMOLY .120" WALL THICKNESS ROOT
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = 4130 chromoly tube
THICKNESS = .120"
WELD TYPE = FILLET
JOINT TYPE = COPED TUBE JOINT
POSITION = FLAT
AMPERAGE = 125-135 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  10
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
tig welding 4130
