Tig Welding 1/8" Aluminum
by Dan
(Canada)
Hi Jody, Love your site and videos!
Just looking for a few suggestions on tigging aluminum.
I am not a welder by trade but enjoy fabricating.
I own a synchrowave 350 LX though and I use a foot pedal.
It also has pulse up to 10 only I think as it was the one just before the Dynasty.
I am welding diamond plate 1/8" and I am having a little trouble getting my welds perfect.
They have however come a long way.
On starting a corner weld some times I get a very slight burn through on the backside.
I am using 125 amps and I am trying to work the rod in there
quickly to help temper the heat.
I have tried to cut the foot pedal back a bit after a second or two and that seems to help.
Clamping and minimizing gaps where possible.
Just wondering if there is something else I could be doing.
Maybe its just more practice!
I love the finger shield idea and will be ordering some soon!
You are on the right track.
make sure to be easy on the amperage while you are joining the 2 pieces together. Once you get both pieces joined , then you can step in and get moving.
A little burn thru on the back side is not usually a problem, in fact, sometimes its a very good thing to let you know you are getting good enough penetration.
regards,
