TIG WELDING 16 GA STAINLESS STEEL CORNER 1F
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS =  .063"
WELD TYPE =  FILLET
JOINT TYPE =OUTSIDE CORNER
POSITION = 1F
AMPERAGE = 45-55 AMPS
FILLER WIRE = .045” ER308L
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
