TIG Welder Settings for Carbon Steel from thinnest to thickest
Use this page like a weld calculator to find settings for carbon steel welds.
Each settings video is under one minute showing an arc shot as well as all settings used.
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
Did you know?...
***Its Easy to sign up
No Ads, No BS style
Top 3 TIG tips
- aim for an arc length that is equal to or slightly less than electrode diameter (arc length is distance from tip of tungsten to puddle)
- limit torch angle to around 15 degrees ( torch angle can be very forgiving provided you hold a tight arc)
- Keep the hot tip of filler rod shielded in the argon plume and snip off the tip for restarts if tip has is discolored... or not kept shielded in argon
