Tig Welder Settings for Carbon Steel Pipe
Each link on this page takes you to a quick one minute or less video with settings used. If you are in a bind and need to know some basic settings , I hope this helps you
6g 2 inch schedule 80 root pass dip keyhole
6g 2 inch schedule 80 hot pass
2 inch schedule 80 2g Root Pass dip keyhole method - Carbon steel pipe
2 inch schedule 80 2g 2 bead cap on Carbon steel pipe
2 inch schedule 80 2g hot pass on Carbon steel pipe
2 inch schedule 80 2g Root Pass dip keyhole method - 309L filler rod and purge UA41 Carbon steel pipe
6g 6 inch schedule 80 Root Pass laywire method - Carbon steel pipe
6g 6 inch schedule 80 Hot Pass - Carbon steel pipe
6g 2 inch Monster coupon Root Pass - Carbon steel pipe
Carbon Steel Socket Weld TIG Settings
1-1/2" schedule 40 socket weld in vise freehand
1-1/2" schedule 40 scratch start tig socket weld walking the cup in vise
2" schedule 40 tig socket weld root settings walking the cup in position tripod vise
2" schedule 40 tig socket weld fill and cap settings walking the cup in position tripod vise
