TIG Welder Settings for Carbon Steel Fillet Welds
primeweld 225 tig with stuff
The problem with most other really affordable tig welders is usually a really cheap foot pedal and TIG torch.  Primeweld went to extra expense to include a genuine CK17 torch with superflex hose along with a very smooth SSC style foot pedal.
A high quality CK dinse adapter is also included so that you can easily swap out a tig torch or cable when the time comes.
Primeweld also has a responsive primeweld equipment users group on facebook and also has demonstrated great customer support
Watch some more primeweld videos and you will see what I mean.
TIG-CARBON-FILLET
jazzy10-2g-aerospace-welding
Tig welder settings for 18 ga carbon steel outside corner joint using chill bars
Tig welder settings 18 ga carbon steel outside corner without chill bars
tig welder settings carbon steel 18 ga lap joint
tig welder settings for 11ga 1F outside corner joint carbon steel
tig welder settings for 1/4" carbon steel lap joint comparing er70s2 to er70s6
Tig settings for 11ga cold rolled steel 2f lap joint
settings for 11ga 2f tee joint carbon steel
