Tig Welding sched 40 Carbon pipe to stainless flange root pass purge settings
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS = 3 inch SCHED 40 PIPE
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = ROLLED IN STANDS OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 95 AMPS
FILLER WIRE = 1/8” ER309L
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = MANUAL
POST FLOW = 10
ADDITIONAL SETTINGS = ARGON PURGE AT 25CFH REDUCING TO 10 CFH AT THE END
TIPS: EXTEND ELECTRODE ENOUGH TO GET A DECENT ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL … Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
var l = window.location.href,
d = document;
