TIG WELD CARBON STEEL 11GA SQUARE TUBING DIP TECHNIQUE 100AMPS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = GROOVE weld
JOINT TYPE = BUTT JOINT
POSITION = 1G
AMPERAGE = MACHINE SET TO 100 AMPS
FILLER WIRE = 1/16" ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = 0.5 SEC
POST FLOW = 8 SEC
TIPS: KEEP A TIGHT ARC
