Tig Welding 6g Carbon Steel pipe .220" wall 2 inch sched 80 root dip keyhole
scroll down for settings
Did you know?..
THICKNESS = 2 inch schedule 80 pipe wall thickness .220"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 6G pipe OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 80-90
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW =  MANUAL
POST FLOW =  10
Snip oxidized tip of filler metal before a restart
tig pipe root
