TIG WELDING CARBON STEEL 1/4" THICK WITH 309L FILLER WALKING CUP FILLET WELDS
METAL TYPE = CARBON STEEL
THICKNESS = 1/4”
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 177 AMPS CONTROLLED WITH PEDAL  BUT MAXED OUT SOMETIMES
FILLER WIRE = 1/8” ER309
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC and adjust electrode extension to same as cup diameter so in this case that would be 1/2"
walking the cup fillet weld
