TIG torch consumables include, ceramic tig cups, collets, collet bodies, gas lens bodies, end caps, tungsten, and more.
The problem in looking for tig torch consumables that fit your torch is...
tig torch consumables have part numbers that don't necessarily make any sense to anyone but the original manufacturer.
for example, how many people know that a 45v44 is a 3/32" gas lens collet body for 9 and 20 style torches?
a 45v43 is a 1/16" gas lens and a 45v45 is a 1/8"
do any of these part numbers make sense to you? me neither.
That's why we put together kits that have the right parts that you can be sure fit your torch.
All you need to know is what style torch you have.
Here is a video that should help...
Once you know what style torch you have, its pretty easy to get the right tig torch consumables because we have ready made kits for your torch at weldmonger.com
Simply knowing for sure what style tig torch you have lets you buy tig torch consumables with confidence they will fit your torch.
..includes #4-8 ceramic cups, along with a clear 8, a jazzy 10 ceramic, and furick 12 ceramic, and a BBW glass cup, along with 3/32" hardware and tungten
Another tig torch consumable is tungsten.
I recommend 2% lanthanated as the single best all around for AC and DC if you are into keeping things simple.
IF you weld mostly Steels, and only occasionally weld aluminum with AC, then 2% ceriated will work well for that.
There is not one single tungsten that works best for very application.
Only tungsten that works best for a particular application.
