TIG WELDING STAINLESS 18 GA OUTSIDE CORNER 2F CHILL BARS PULSE SETTINGS
Sometimes, in order to avoid distortion and discoloration on stainless, chill bars and pulse settings are worth the extra effort and time to set up
THICKNESS =  .063"
WELD TYPE =  FILLET
JOINT TYPE = CORNER
POSITION =1F
AMPERAGE = MACHINE SET TO 110 AMPS CONTROLLED USING PULSE SETTINGS ALONG WITH FOOT PEDAL
FILLER WIRE = NONE... AUTOGENOUS WELD
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   PULSE SETTINGS 110 PEAK AMPS,  1.5 PPS, 30% PEAK PULSE, 5% BACKGROUND WITH CHILL BARS
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
