TIG WELDING STAINLESS PULSE SETTINGS 1/8" SHEET TO PIPE
A big part of tig welding stainless steel is heat control.
Sometimes pulse settings can help prevent excessive build up of heat.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS =  .125” PLATE TO TUBE
WELD TYPE =  FILLET
JOINT TYPE = TUBE TO PLATE
POSITION = 2F
AMPERAGE = 150  AMPS.
FILLER WIRE = 3/32” ER308L
GAS FLOW = 20CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =    PULSE SETTINGS 1PPS, BACKGROUND CURRENT 20%, PULSE ON TIME 50%
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: GET THE PUDDLE MOVING WITHIN 3 SECONDS to avoid heat buildup
