TIG WELDING STAINLESS 11GA thick 2f OUTSIDE CORNER
Scroll down for details and settings used for this stainless outside corner joint
THICKNESS =  .125"
WELD TYPE =  FILLET
JOINT TYPE =OUTSIDE CORNER
POSITION = 2F
AMPERAGE = MACHINE SET TO 120  AMPS CONTROLLED WITH FOOT PEDAL TO AROUND 100
FILLER WIRE = .045” ER308L
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
