Tig Pulse Settings .080" outside corner carbon steel
METAL TYPE = CARBON STEEL
THICKNESS = .080”
WELD TYPE = FILLET WELD
JOINT TYPE = OUTSIDE CORNER
POSITION = 2F
AMPERAGE = MACHINE SET TO 105 AMPS CONTROLLED WITH PEDAL USING PULSE SETTINGS
FILLER WIRE = NONE
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PULSE SETTINGS 1.5 PPS, 20% PULSE TIME, 15% BACKGROUND CURRENT
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
Did you know?..
