The Best TIG Gas Lens kit for your tig torch
The Best TIG Gas lens kit for you is the one that has the right cups and hardware for your torch.
... and the right cups for the type of welding you are likely to do.
Having a kit that has every cup you might need for any situation can save you time, money, and aggravation.
And you can be sure all the hardware fits your torch.
Do you know what style TIG torch you have?
If not, The short video above and these pics below will help you identify your tig torch.
Why Even use a Gas Lens?
If you watched the short video directly above, I think you will agree with me that a gas lens can make a big difference as opposed to the standard cup that comes with most tig torches.
I assure you, its not a parlor trick.  I tried to keep all the variables the same as far a stick out and amperage.
Once you get to a certain stick out , the gas lens out performs the standard cup...much shorter stick outs work better with standard cups but sometimes you absolutely need a longer stick out.
We have TIG Gas lens kits for practically every situation.
TIG welding 4130 chromoly cluster joints? Stainless steel, Aerospace alloys like inconel 718, hastelloy x, waspalloy, titanium, 17-7 ph stainless, L605, tool steels?
Any of these kits will be great for that
Sanitary Stainless tubing on breweries, food service, hemp distilleries?
There are several tig gas lens kits that would be great for tig welding sanitary stainless tubing and any other food service stainless welding.
Aluminum tanks, dog boxes, first responder vehicles?
There are so many different situations you get into with welding aluminum but we have kits for practially everything.
We just revamped our large diameter gas lens kit to included 5/32" tungsten and hardware for those higher amperage aluminum welds like an outside corner joint on 1/4" aluminum tread plate where a 1/8" tungsten just wont cut it.
We also have an Aluminum Pro kit with some of the most popular cups you see the pros use like the ally 5 clear cup and the standard 5 ceramic cup with standard collet body.
These kits are all great for aluminum depending on your type of work.
Ally 5 combo
8 pro combo tig gas lens kit
stubby gas lens kit
aluminum pro kit
large diameter gas lens kit with 5/32" hardware and tungsten
What about Titanium?
Furick Arsenal kit
furick ultimate pro kit
TIG pro kit
All these kits have the Furick BBW cup for tig welding titanium
TIG Arsenal kit
we recently redesigned our tig arsenal kit to include standard gas lens cups 4 thru 8 for those situations where you want to save some argon
