TIG WELDING CARBON STEEL THINWALL .063" TUBE LAYWIRE 3/32" ROD
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL SQUARE TUBING
THICKNESS = .063” WALL THICKNESS TUBE
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT JOINT
POSITION = FLAT
AMPERAGE = MACHINE SET TO  70  AMPS CONTROLLED WITH PEDAL  60-65 AMPS SWEET SPOT
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   PRE FLOW = .5 SECPOST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC ..
practice restarts until they blend in
