TIG CARBON STEEL PIPE 2 INCH SCHED 80 2G HOT PASS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS = 2 inch schedule 80 pipe wall thickness .220"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 2G pipe OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = MACHINE AMPS SET TO 110 USING LIFT ARC
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = manual
POST FLOW = 10
Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
var l = window.location.href,
d = document;
