TIG CARBON STEEL 2 INCH SCHED80 .220" WALL THICKNESS 2 BEAD CAP 2G
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
THICKNESS = 2 inch schedule 80 pipe wall thickness .220"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 2G pipe OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 110 AMPS USING LIFT ARC
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW =
POST FLOW = 10
var l = window.location.href,
d = document;
